Mowing Mower lift BX1870
   / Mower lift BX1870 #1
eutectic64
Porter, Texas
BX1870V
When I try to turn dial to put mower deck lift to "TOP". It wont go! I can move dial freely to all numbers but wont go into "TOP"
Any Help?
   / Mower lift BX1870 #2
Check for mud, dirt, etc. encrusting the linkages. Clean, then spray area with WD40 or similar. If this doesn't work, adjust large gold or silver hexhead bolt next to left rear tire. First loosen the locknut, then tightrn the bolt little by little until you can turn the knob to Top.
   / Mower lift BX1870 #3
Adjustment on the rear of the tractor between the drivers side rear tire and case. Its a gold anodized bolt. Undo the jam nut turn it one full turn and tighten the jam nut. Your hight adjustment will go to TOP.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
2011 Ford F-150 4X4 Pickup Truck, VIN # 1FTFX1ETXBFC66737 (A51572)
2011 Ford F-150...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
