mower for a 3x20
   / mower for a 3x20 #1
norgeman
Wisconsin
john deere 3320
This coming week I am going to purchase my jd 3120 and would like some advice on what model finishing mower I should buy for it. I am retired and plan on cutting and keeping the grass short in my flat pastures.
   / mower for a 3x20 #2
I personally like the Frontier/Woods brand RFM's. I had a 60" SD RFM and it cut great. I traded for a larger economy Frontier (I believe made by Befco) which I like but not as well as far as cut. (It does mow faster). I am a fan of the Imatch hitch, but several brands offer good models. Befco, Woods, Frontier, Bush Hog, LandPride all consistently are at the top of the list. The only additional advice is choose the highest blade tip speed you can (16,000 fpm is a good goal) and if you go with Frontier, I would get the 1060 or 1072 standard with Rear Discharge, not the Economy. They are better cutting mowers. Also, your 3120 WILL pull a 72" mower no problem, so I would get that over the 60" unless you have lots of hills or tight spaces to negotiate.
John M
   / mower for a 3x20 #3
Welcome. Is the MMM out of the question?
   / mower for a 3x20
Thanks John, Today I am going to purchase my 3120 and will certainly take your advice. Earl M
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
