mower deck will not raise or lower
   / mower deck will not raise or lower #1
Trackks9
Bronze Member
green bay, wi.
pt 418/ IHI mini excavator
troubleshooting chart say's be sure hyd. cyl. lockout valve is open, must be a
option, I don't see one, this is on a x475
   / mower deck will not raise or lower #2
I just got my X475 and am still trying to learn about it. I notice my deck will sometime raise/lower and sometimes will not do anything. I haven't mess with it much but I want to test it to see if it has to be at full throttle. I notice it will not raise/lower when I have the throttle at idle. Also, make sure you have the correct amount of oil in the transaxle. I don't know enough to know how the system works with pumps and pressure. It could be a pump problem or just a valve problem if you have enough oil in the system.
picture.php
homepukes I sent you a PM
   / mower deck will not raise or lower #4
Did you figure anything out?
   / mower deck will not raise or lower #5
Just be sure the valve is open when using the mower deck.
Turn's out the height control knob was screwed up. when I set the height to a
high setting, the lift arm's came up to the frame, an easy fix, the mower deck
need's to be reset, over all I am really happy with the tractor.
   / mower deck will not raise or lower #7
Trackks9
:D
beenthere, donethat! ;)
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
STEEL SLINGS (A54757)
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
(APPROX. 250) UNUSED LANDHERO 30" TRAFFIC CONES (A54757)
(APPROX. 250)...
