Mower Deck Gear Oil
   / Mower Deck Gear Oil #1
RTJ49
Kubota BX 25 & DZ 323
My Kubota ZD 323 calls for 90w gear oil. What is the difference between straight 90w and 75/80w or 80/90w gear oil?
Is any of the other gear oils ok to run?
Thanks,
RTJ49
   / Mower Deck Gear Oil #2
You have the "w" in the wrong place... (which stands for winter).
75w90, 80w90 etc are both 90 weight gear oils. The lower W(inter) will just thicken less in colder temps.
All that said, I have always run 75w140 in all gear cases I have, including the ZD mowers,
   / Mower Deck Gear Oil #3
In equipment that specifies 90 weight (there are some great internet arguments about whether the "W" stands for weight, winter or winter weight, but they don't matter to us) I always use 75w90 synthetic. I personally don't care for the 75w140. Heavier is not necessarily better, especially for high speed gearing, because it is more likely to not flow well and I like to stay close to the manufacturer specifications. I think it's important to run synthetic since these units go so long between changes.
   / Mower Deck Gear Oil #4
I use whatever I had on the shelf. Changed my finish mower with some 85W90 and my brush mower with some 85W140. I am in FL so the heavy oil won't matter. My Howse mower recommended the 85W140 and my Chinese finish mower recommended the 85W90 so I was good on both counts. I would have used either oil in either mower but since I had them already I stuck with what the manuals said.
   / Mower Deck Gear Oil #5
All things considered stick with the OEM specifications.
On the other hand any oil or even grease in a consumer tractor gearbox will do fine for a decade or 2 under normal use. Lots of people (including myself) put grease in older gearboxes rather than replace leaky seals letting all the gear oil out. They last for years or decades in that shape.
flooring (A53424)
flooring (A53424)
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55218)
PENDING SELLER...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
