Oil & Fuel Mower Deck Gear Box - 62c
   / Mower Deck Gear Box - 62c #1
steveschlutt
St. Joseph Michigan
John Deere 2210
I realized at 880 hours that my 62c mower deck has never had the gearbox fluid changed. The manual recommends it be done at 500 hours. So I removed the gearbox, and wrestled the plug out (wow- that was some really strong sealant), and expected cruddy sludgy goop after going the extended interval. But what came out looked pretty good-- still had a nice caramel color, and looked pretty clean. My question-- the manual says John Deere GL5 goes in there... is that 80-90, or 90-140? I happen to have a bottle of Valvoline GL5 80-90, and would like to use that up. It really only takes about 1/3 of a quart. This is on a 2210 Tractor.
   / Mower Deck Gear Box - 62c #2
They are just recomending that you use gear oil. The grade will be dictated by the normal ambient temp while in use, for the most part these gear cases where not too picky. You are probably just fine with the 80/90 you have. For wintertime use, maybe something a little thinner but who mowes in the winter. The same book you got is the same book a guy in alaska got and the same one a guy in texas got so grades can be a little vague.
   / Mower Deck Gear Box - 62c #3
As MORRISONSTEEL mentioned it is a matter of environment. John Deere GL5 is a 80-90W oil.
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
A & B 5' 3pt Blade (A50121)
A & B 5' 3pt Blade...
Massey Ferguson 383 (A50120)
Massey Ferguson...
