Mower Deck engage problem on Toro ZTR
/ Mower Deck engage problem on Toro ZTR #1
TallMinnesota
USA
Toro 74204
I have a Model 74204 Toro ZTR with 500 plus hours. I know my battery needs to be replaced but I jumped it and it starts and runs fine. It suddenly started to run very rough while mowing. I disengaged the mower deck and it runs fine. I tried to reengage the mower deck several times and it would not reengage. After shutting down the mower and jumping the battery again it started and the mower deck will reengage. I am not sure about the electrical part of the Clutch part number E631732 (costly item) and the switch part number 103-5221 (old part number E633673). What might be causing the problem? I replaced both ignition coils last year and the engine idles and runs fine.
Thank you, Bill
/ Mower Deck engage problem on Toro ZTR #2
Need to test Battery and charger / output system. unit may not be putting out enough power to run electric clutch. Just wondering why you had to replace both coils?
Thank you for the reply my guess is you are exactly right about the battery. I did not understand the "electric clutch" concept and I will charge the battery and see if it discharges and the same problem reoccurs.
I replaced the coils when I started having problems with a fouled spark plug and rough running engine. I assumed it was a problem with the coil and took it out and had it tested. It was dead or close to and the tech, who I trust, suggested I replace both as the new and old coil will put out different levels of spark power. I agreed as I had the shroud off and OEM coils were only about $37 apiece. The mower ran great for the rest of last summer and fall and initially this spring but I imagine the battery sitting in an unheated garage over the winter in Minnesota may have killed it.
Thanks again for your reply. Bill
If the battery doesn't charge is it possible that the Rectifier (Part number 2540303) needs to be replaces? Is it the rectifier that causes the battery to be charged when the engine is running?
/ Mower Deck engage problem on Toro ZTR #5
If you have a volt meter you can test to see if getting charge voltage. I believe that unit has a dual system in it. The other system will power the clutch. There is also an interlock module on it too.
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
100 Manure Spreader (A66408)
100 Manure...
2022 EZ-GO ELITE...
