mower deck belt problem
   / mower deck belt problem #1
digger2
n.e. pa.(lycoming co.)
kubota B26 TLB,former B7610 owner
Please give me a answer to this,if anybody knows.
I've got a 1987 Bolens ST125 hydro riding lawnmower.Your basic rider-
42" deck,recently replaced engine,new blades and loose steering.
Anyway,for a machine as old as it is it works great except for one thing.
I cant find a belt that lasts on the mower deck.It does'nt chew them up or wear them out.What happens is the inside of the belt,the "v" side,starts cracking shortly after i put a new belt on.My last two belts lasted no more than two months.Actually,one only lasted two weeks before it started cracking on the inside and broke.The outside looked like new yet.
I was told by the guy behind the parts counter that i needed a 'HEAVY DUTY" belt if the belt ran on its flat side on any idler pulleys.Well i have three
idler pulleys like that on my deck where it does run around idlers in the shape of a "U". The belt i last used was their "HD" belt,and it did'nt last as long as their regular duty belt.This belt is 158" long and is'nt cheap if i have to keep replacing one every couple of weeks.This mower is'nt used in heavy grass at all.I've never had this problem with a mower belt.Any answers???
digger2
   / mower deck belt problem #2
My first thought was your belt supplier stocked up on your size belt in 1982 and they are cracking from age. But then I got to thinking you didn't mention where you are getting these belts. autoparts store? Tractor Supply Co? Some belts are not manufactured to run on small diameter pulleys as well as others. But I'm not sure where to get genuine replacement part belts as the original manufacturer of your tractor doesn't exist any more... maybe MTD has them?
   / mower deck belt problem #3
I'm assuming the belt is running around the pullies in the correct sequence . It may be worth trying a cogged belt as they are less prone to cracking going around tight radius pullies . Gates or Dayco would be my choice .
   / mower deck belt problem #4
Was the belt fabric covered or just plain black rubber?
There are a heavy duty belts made for mowers. The ones I have used are totally encased in green or blue fabric. The fabric is to allow a degree of slippage but I guess it would provide extra strength for a belt that bends 'backwards' around the pulleys (as many mowers do.).
I'm getting the belts from a good size lawn tractor dealer-they sell everything from Grasshoppers to Echo weedeaters.
The belt is running correct as theres a diagram sticker still on the deck.
Also,the belts are Gates.They are black but not just plain rubber.They have a canvas covering all around.The last one i got was called a Green Stripe 2.
I know what you are talking about as far as the green belts.My dealer says they cant get this belt in that size(??????).
Somebody told me today that TSC carrys belts for garden tractors made with Kevlar.I'll have to check it out......
digger2
   / mower deck belt problem #6
Not that I'd really know, but yes that does sound like a big belt for a ride-on.
I get my belts from a specialist belt/hose shop. Most cities will have one.
They are quite a bit cheaper than the local mower shop.
   / mower deck belt problem #7
Have you checked your v pulleys for wear? It has been 21 years they might not be "v"'s any more. Also idferent belts have diferent pitch to the v and you may not be getting proper contact between the belt and pulley causing the belt to get pinched in the inner portion of the pulley. Just a thought.
   / mower deck belt problem #8
I agree; check pulley pitch; may be getting wrong pitch belt. Might be easier to get pulleys.
   / mower deck belt problem #9
If you have the dimensions of the original belt you can usually get a kevlar replacement at a farm machinery dealer:) I have a craftsman that did not seem to like to keep belts after mowing a few rocks:eek: The deck belt seemed to me to be pretty expensive so when I was getting parts for something else at a farm equipment outfit I asked about belts and blades -- no problem much cheaper and they suggested kevlar (also cheaper than Sears) I have not broken or damaged the belt in over two seasons (and I still mow rocks occasionally:(
Ps --make sure those pulleys actually turn and the tensioner is functional - sounds like the belt is taking abuse from some part of the setup
   / mower deck belt problem #10
Cracks as you describe imply that the belt is seeing more curvature than it was designed for. Look for an idler pulley that's too small. This might mean you need to change the belt length as a result. If the deck is not the original, check to see if the pulley width and v-groove is the same as the driving pulley groove. On my Simplicity, the deck pulley was 3/4 and the clutch pulley was 5/8". Somebody added a 48" deck to a system that came with a 42" deck. Oops....
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
