Mowing Mower Blades
   / Mower Blades #1
tlb
Austin, TX
PT 425
Does anyone know an alternate source for mower blades? I have the 60" finish mower (3 blades) for a PT425.
Thanks,
-Tim
   / Mower Blades #2
Thanks,
-Tim
I don't know where he got them, but when I bought my 425, Rich gave me a spare set of blades that he'd purchased locally. If you'll take one off and carefully measure them, including the size and number of holes, I'm sure you can find some.
Here's one on-line source that has a huge inventory of blades:
Snowmobile Parts, ATV Parts, Go Kart Parts, Mini Bike Part, Lawn Mower Parts, Chainsaw Part and Small Engine Parts
BTW, they also have solid rubber-tired caster wheels that will replace the ones on the PT attachments -- that's why I have it bookmarked.
   / Mower Blades #3
Hey tim, Mowpart.com has them. Their oregon brand part# 90-125...just under $5 a blade, exact replacements.
Kris
   / Mower Blades #4
Kris
Are these the same as the ones used on the 48" mower too? :confused:
Thanks for your help!
   / Mower Blades #5
Id have to say no, Just because the measurments dont add up. Do you have the original blades? If so check them for a part #. Chances are their made by oregon. My blades had the part# right on them and I just typed the part# in at mowpart.com. Basically just plain old thin gauge generic blades but they cut well , and are cheap. If you just look under universal blades you should be able to find the appropriate size (length and width) with the correct center hole of 3/8" (at least on mine) I would however stick with a blade on the thinner side so as not to put undo stress on the spindles.
Kris
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
Valvoline Brake Fluid (A53117)
Valvoline Brake...
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
2016 DUTRHMEN ASPEN TRAIL 2460 RLS TRAVEL TRAILER (A51247)
2016 DUTRHMEN...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
