Mow with MMM with rear attachment still on 3 point
   / Mow with MMM with rear attachment still on 3 point #1
oozie10
Yanmar 324
Anybody figure out how to leave a rear attachment on and still mow with your MMM on your SA324?
This is not something I would think I would want to do often but maybe if I was trying to multitask and not unhook the rear attachment.
   / Mow with MMM with rear attachment still on 3 point #2
Does your tractor have a dial you turn to adjust the rate of drop on your 3 point? It’s usually just in front/below the seat. Turn it all the way in and lift the 3 point all the way up. That should lock the 3 point in place. Not sure if your mmm will lower still but you can try?
   / Mow with MMM with rear attachment still on 3 point #3
oozie10, You can use the mower with an attachment still on unless it is a backhoe then you haver to remove the b/h to use the mower
   / Mow with MMM with rear attachment still on 3 point #4
I have the SA424, same as the SA324 except for tire size.
The MMM linkage connects over the left 3ph lift arm. Thus when you lower the MMM which is accomplished by moving the 3ph lever, any implement on the 3ph will also lower.
I would also like to mention that the MMM can be locked in the up position and allows for independent use of the 3ph without removing the MMM. Ground cleananrce however may be reduced.
I purchased a 3ph quick hitch and that has greatly simplified switching over from a rear implement task to the MMM. I mow with the quick hitch installed.
I do have a quick hitch. That's does make it very easy to take off a rear attachments.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
