Moving snow banks, what is the better method?
   / Moving snow banks, what is the better method? #1
gogojuice
Canada
Kubota
I have used my rear blade to move the snow. Works pretty well for snow under 6 inch. However after a while there is a build up. I'm wondering how to move it.
I have a bx2670 with FEL and the rear blade.
I may be able to push it back with the rear blade, but it would push the 3pth up. I don't have any extra weight to keep it down. Would this cause any damage to the 3pth as push it backwards and the hitch rides up?
Or, would it be better to use the FEL and move it?
   / Moving snow banks, what is the better method? #2
I use my FEL and this year my new quick attach blade to push banks back. I am talking about 6 foot or so banks built up by my plow truck.
   / Moving snow banks, what is the better method? #3
If the snow is still loose use the front end loader rather than the rear blade.
   / Moving snow banks, what is the better method? #4
FEL to push back banks.
Have you consider front plow attachment,front plow keep banks push back first shouldn't be problem.
The snow is now compacted. That is what made me think that I might cause damage if I try the rear blade on the 3pth.
Thomas. I would also love a front mounted snow blower. Seems to me that would be the best / quickest method out there… Rear blade to quickly clear the snow out of the driveway, and then snowblower down one side and move it far far far away lol. But.. I have to work with the equipment I have.
Thanks for the help guys :)
   / Moving snow banks, what is the better method? #6
Try not to push with a rear blade...lots of bad (expensive) things can happen.
   / Moving snow banks, what is the better method? #7
Hate to say it, but this is to be avoided in the first place. I try never to move stuff more often then I have to. Time to bring in the bug guns. Some three yard loader should do nicely.
Yes, front mount blowers are the cats meow! But many don't blow far enough, and don't work well if you are trying to blow into the wind.
Unless you have some serious equipment and horsepower, I would not try and move an existing pile with a blower. You are liable to break something!
   / Moving snow banks, what is the better method? #8
Use eighter doesn't matter turn rear blade around to push if you need too
   / Moving snow banks, what is the better method? #9
or go to florida till spring and hopefully snowbank will be gone when u return,,,:laughing: I use front end loader
   / Moving snow banks, what is the better method? #10
These two should do it
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
RIGID TOOLBOX (A52472)
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
