Moving Dryer size Rocks !!
   / Moving Dryer size Rocks !! #1
TC33DRon
Town of Flordia NY 12010
NH TC33D
Have a new home and need to move some large rocks.
FEL will not pick up that size rock. Tryed...wont go.. Pushing, slow at best, if round rock,,, Maybe pull it around on some sort of skidd ?? Anybody have any suggestions.. Dont want to spend a lot of cash for equipment only to use it one time. Any thoughts??
Thanks Ron
   / Moving Dryer size Rocks !! #2
Make yourself a "stone-boat" -- a heavy duty sled that you drag with your tractor to haul the rocks.
Here's one example
EDIT: The advantage of this design is that you open it up and put it on each side of the rock, with the opening at the front. Run a chain through one clevis and hook it to the other one. When you pull forward, you pull it under the rock -- then pull the rock... No more hassling with loading the rock onto the stoneboat.
   / Moving Dryer size Rocks !! #3
The hood off of an old car with a couple of holes burned through it for a chain works well. It aint really pretty but it gets the job done cheaply.
   / Moving Dryer size Rocks !! #5
One post said use an old car hood. You might be surprised at the size of rock that you could push on to a hood with that loader. Then hook the tractor back up and pull it away.
Great!! Ask and you shall receive.. Thank you all, for your years of learning and sharing.
Ron
   / Moving Dryer size Rocks !! #7
I've had luck moving somewhat smaller rocks with a POS jeep I had- and a sheet of plywood. Same idea as the car hood- pushed the rock on the plywood, chained it to the jeep and away you go. The car hood should be real slick. good luck
   / Moving Dryer size Rocks !! #8
Just remember that a rock on some type of skiding device may have to answere to the call of gravity when steeper slopes are encountered. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / Moving Dryer size Rocks !! #9
A stone boat is just what you need. Every farm around here uses one. I did have a old car hood stone boat, but it got too ripped up.
I am going to build a new one out of 2 X 8's and 4 X 4's this spring. Bend 1/4" steel plate up in the front for a shoe, attach a chain and bolt boards together with carriage bolts.
Be sure to be careful on downhill's as gravity is holding the rocks in place. I use the loader to dump the load, just catch the corner of the stone boat with the bucket a flip over.
ksmmoto
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
Gurney (A50325)
Gurney (A50325)
44511 (A51692)
44511 (A51692)
