Moving cut tree branches & logs
   / Moving cut tree branches & logs #1
Aggie66
Bronze Member
Rockdale TX
MX 5400
I have a large oak tree that the wind blew down along our creek. It’s probably 50 ft or so tall and trunk diameter of near 36 inches. I plan on piecing it out with a chain saw and using my MX5400 to drag the cut pieces out. My question is:due to working along the creek bank I’ll have to use chains to drag the cut pieces out. I don’t have front weights so I don’t feel comfortable using the drawbar but I’m not sure how much lifting/pulling I should do with the hooks on my FEL bucket. Anyone who does a bit of “logging” comments appreciated. Thanks
   / Moving cut tree branches & logs #2
I have a MX5200 which will move a surprising amount of log. I think the main issue will be the log sections not getting hung up on something during the pull that could cause any tractor to flip.
One thought that comes to mind is to buy a length of cable, a tree strap, and a couple of pulleys that would enable you to rig a pulley to a nearby tree and use mechanical advantage to lift up and pull the log sections out of the creek if needed?
I would use the drawbar rather than bend the FEL.
   / Moving cut tree branches & logs #3
100% pull from your drawbar before yanking on it with your FEL.
I don't think you'll need any front weights, but if you think you do just take a scoop of something like dirt or sand to fill your bucket, that will give you plenty of ballast up front.
   / Moving cut tree branches & logs #4
Your 3 pt is capable of lifting well over 2000 lbs. If you have a rear blade, you can use chains to then use the 3 pt to lift one end of the cut pieces to facilitate it dragging out.
   / Moving cut tree branches & logs #5
The FEL's on these CUT tractors are designed to lift & push, not pull. It's fairly easy to bend something while dragging too heavy a load. This is especially true if you pull at an angle.
I'm not sure why you aren't comfortable pulling with the drawbar. That's what it's designed for. If you can't get enough traction, cut the logs into smaller sections.
A grapple on the FEL is ideal for moving logs, limbs & brush if you can rent or borrow one. When lifting with the grapple, the weight of the log acts as ballast and can increase traction.
  • Good Post
Reactions: JWR
   / Moving cut tree branches & logs #6
Much of this depends on whether the creek is deep and has steep banks.
I'd be very, very careful about operating near a creek bank that could give way or somehow end up with your tractor tipping over. This is partly why I suggested using a nearby tree as anchor point for a pulley to both lift and pull the tree sections out of the creek using the drawbar. A long enough cable should enable you to operate your tractor a safe distance from the creek bank. Premade cables with hook ends, tree straps and a pulley can be had on Amazon affordably.
  • Good Post
Reactions: JWR
   / Moving cut tree branches & logs #7
Like everyone else I say pull using the drawbar in rear. DO NOT HESITATE to use that drawbar. By design the drawbar is BELOW the rear axle level so when you put a lot of force in pulling on the drawbar you are adding weight to the front wheels, not lifting them. You cannot tip the tractor if hooked up like that, as it should be. We can't see your creek bank or details of the pulling situation...just try a few and see how it goes.
   / Moving cut tree branches & logs #9
agree w/above, draw bar, not 3ph
Double that! NOT the 3ph tool bar!
The draw bar will actually force the front end down on an over load. (to an extent)
I have land that is a series of terraces.
I also have a 50 foot length of 1/2 inch cable with eyes at each end, a 15 foot cable choker, and about 80 feet of stout chain.
Stay away from any land that can tip the tractor over. Penny wise, pound foolish is not the way to go.
You can always make a couple of extra cuts and a couple of additional pulls.
I run one of these on all my tractors.
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
Adams Conveyor (A51039)
Adams Conveyor...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
