Moving concrete pipe
   / Moving concrete pipe #1
MrWhippy
Maryland
Ford 1710, Ford 5600, NH Workmaster 55
I have 2 8 foot sections of concrete pipe coming. We're using it to prevent washout on a couple spots on the bridle path around the farm.
Each section weighs slightly more than 2500 lbs. I have a Workmaster 55 with FEL and BH attachment. I also have 3PH forks. I'm trying to decide the best/safest way to move these things.
Options:
1. Strap it to the FEL and put the mower on the back
2. Grab it with the BH and thumb (with wood for cushioning), lift and drag
3. Slip the forks under it, lift and carry
I've also thought about running a pole through it and using straps on the pole to lift and drag.
Anybody have experience with this? I'd hate to break these pipes due to poor transportation...
   / Moving concrete pipe #2
I do have a lot of experience with the pipe, unfortunately it is with bigger equipment. I'm not familiar with the specs of your tractor. If your FEL will safely lift the 2500 lbs and your forks are rated for the weight, then I would use the forks under the pipe. Obviously moving them one at a time. If you can't safely lift and carry the pipe, I would look into renting, or hiring, a larger piece of equipment. How deep are you laying the pipe and how far do you have to move it?
The pipe will go just below ground level (26 inches or so). We'll be moving it around 1/4 mile or so, but through a field, so the ground is a little rough.
The plan is to dig a "ramp" so the pipe can be rolled down into place rather than trying to lower it into a trench.
   / Moving concrete pipe #4
Setting the pipe in place might be the next issue too. Most contractors use a C shaped hook with a long lower support that slides into the pipe. this enables them to position the pipe in place in the trench. Might need to borrow or rent this from the pipe supplier to install.
I would agree with moving to the location with forks if your tractor is capable.
   / Moving concrete pipe #5
I agree with the forks if your tractor can handle it. Be sure the pipe is cured fully also. My dad is a crane operator and i have heard countless storied on pipe like that shattering if not fully cured and/or secured right, physical size has alot to do with that too.
I would suggest a good pair of lifting straps wrapped around the pipe at lifting with the hooks on the bucket if your tractor can handle it.
Zac
   / Moving concrete pipe #6
Kinda off-topic, but why not install ADS plastic pipe with smooth interior?
With shoveled bedding and controlled backfill, it will provide good support.
   / Moving concrete pipe #7
That's a good question. I was trying to help with the original questions, but you bring a good point. I personally would use ADS double wall if it was mine. Especially for longevity, price, and ease of installation.
   / Moving concrete pipe #8
In a similar situation on my place, I would also opt for the plastic culvert pipe.
If the FEL won't heft the concrete pipe, you might be able to either travois it or cobble together a stone boat to drag it to its final resting place.
BOB
Will plastic pipe (double walled stuff) handle a tractor/mower driving over it regularly? I was worried about the strength of it.
   / Moving concrete pipe #10
If there is gravel over the top of it. At lest 6" or so packed and that will carry a lot of weight. I think done correctly a gravel truck could drive over it.
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
Sterling AT (A53473)
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
