We need to temporarily move the well pressure tank to facilitate building of the new pump house. Like 10 feet. Our well is ~ 160' deep with a 6" casing. Submerged pump. Obviously I'll pull the breaker and drain the water out. What isn't so obvious is do I need to relieve the air pressure from the tank to protect the diaphragm? The tank itself is an 85 gallon upright that was new in 2014. There is what looks to be a anti back flow valve in between the well and the tank, no shut off valve. Is it best to keep a barrel of water in case the pump needs priming? Thanks.
