Move x728 tractor when not running
   / Move x728 tractor when not running #1
jbgood
Wisconsin
2013 JD X738
Question is, refering to X728 or X738. If the the tractor is not running or won't run. How do you disengage the transmission and or differential so you can push, pull or winch it onto a trailer or move it around the shop ?
   / Move x728 tractor when not running #2
Should have a rod on the back that you either push or pull and lock so you can roll it.
   / Move x728 tractor when not running #3
my x728 has a lever on the rear right side outside of the frame above the rear axel that moves up and down which engages or disengages. there is a pad on the end of the rod.
   / Move x728 tractor when not running #4
Heres a picture I took of my year 2010 John Deere x728.
The lever looks to be about an inch above the little sticker that says to push manually. You just push the lever up and you can push the tractor by hand, I am at 200lbs and average strength for an old guy and I can push mine myself but you have to lean into it. If you forget its up when you go to start up the tractor and move it, it automatically goes back down.
Rob
Okay guys, Thanks. Just one those Lil' things I was thinking about before I see the dealer. Plan on going this coming Sat.
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
