Sprayer mounting sprayer to 3ph
   / mounting sprayer to 3ph #1
rosey
Appomattox, Virginia (Central Va.)
Kubota BX2200
I want to mount a 40 gallon sprayer to the rear of my sub-compact tractor's 3ph. Anyone know of an implement that would attatch to the 3ph to attatch the sprayer to?? Brand, company???? I'm not interested in building my own and have done a search with no luck.......Thanks
   / mounting sprayer to 3ph #2
Look in this forum for a thread on chinese implements. Follow the attached link in the OP. I recall there was a 3pt mounted carryall box for about 3-400 (?). It looked big enough to hold a sprayer.
   / mounting sprayer to 3ph #4
I have a 3 point bale carrier that basicly looks like a set of pallet forks that goes on the 3 point. I removed the spear part. Kind of a heavy duty version of the carry all that is available at TSC or most tractor places for less then $100.
I then got an extra wide wooden pallet that fits over the carrier.
I then bought 2 lashing straps from HF for $2 and strap the sprayer too the pallet. I then bungie cord the battery pack beside the sprayer, and away we go spraying stuff.
Cheap, I use it for multiple purposes, and it works.
Here is the carry all that KK has. I am sure there are multiple versions out there.
King Kutter Incorporated
   / mounting sprayer to 3ph #5
Rosey
Northstar makes 3ph sprayers they are sold by Northern Tool and Equip.
TSC and Agri Supply Sell Fimco 3ph sprayers also.
   / mounting sprayer to 3ph #6
Yep, you can easily customize a carry all to fit your needs.
Thanks for all of the tips........went to Tractor Supply and bought a "King Cutter" carry-all for my 3ph , and a 15 gallon electric sprayer (on sale 79 bucks) that I'll bungie cord on. Gonna be busy tomorrow spraying round-up on the gravel drive. Should be a little easier than the 2 gal. pump sprayer that I've been using!!
   / mounting sprayer to 3ph #8
Hey Rosey,
Can we have some pics when your done?
   / mounting sprayer to 3ph #9
Rosey, CHECK THE BOXES for that sprayer. We just picked up a 25 gallon ATV sprayer at TS, and the fella there had the presence of mind to open the boxes and check for everything. Apparently, several have been returned for missing or wrong parts. Sure 'nuff, there were TWO pressure gauges, and NO fitting for the pump outlet. They called the nearest coupla other stores, to no avail. Nothing on the shelves. We searched all over town (Viroqua / Westby, WI), and nobody had it. Went back to TS, and the same fella had searched high and low in the warehouse, and found another of the same part. So we're in business for this weekend. But don't get too far without being sure you have all the bits and pieces you need.
Bill Barrett said:
Hey Rosey,
Guys..I attatch some pictures as soon as I can figure how to do it.....bought a new digital camera and am still a rookie at using it and attatching photos to this forum...........
72In FEL HD Round Back Bucket (A52748)
72In FEL HD Round...
Xtreme XR1045 (A50120)
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
John Deere 469 (A50120)
John Deere 469...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
