Backhoe MOUNTING BT750AR ON A L275 DT
   / MOUNTING BT750AR ON A L275 DT #1
madfly
MONCKS CORNER, S.C.
85 Kubota L275 DT, 1957 Fordson Dexta, 69 JD 110, 59 david bradly, 71 sears SS14,74 Allis, 73 cub w/ tiller & MORE
I JUST PICKED A 1884 L275 DT WITH A LOADER, 4WD. A FEW DAYS LATER BOUGHT A BT750 AUTO RETURN BACKHOE THAT COMES ON A B20. I FOUND A QUICK DISCONECT MOUNTING BRACKET AT A TRACTOR SALVAGE YARD, ITS ON THE WAY.MY LOADER IS POWERED OFF THE PRITORITY VALVE UNDER THE SEAT. MY QUESTION IS ,CAN I TEE OFF THAT LINE AT THE VALVE TO POWER THE BACKHOE AND TEE OFF THE RETURN . AND SECOND CAN I DISCONECT THE AUTO RETURN FUNCTION OF THE BACKHOE ,SINCE THE IS NO WHERE TO PLUG IT IN. OR DOES IT JUST REQUIRE A 12 VOLT SORCE TO FUNCTION. THANKS MIKE
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
