Mid-Mount Mower Mounting a mid-mount mower
   / Mounting a mid-mount mower #1
RichardM
Gainesville
John Deere 1998 770
OK, OK so I'm a klutz. It took 2 of us 40 min. to mount a 60 inch belly mower on a JD compact (770 ) tractor. We couldn't drive over it, had a hard time getting it under the tractor to manuver it into place. We finally had to run the front wheels onto ramps so we could get the deck under the tractor.
Does anyone have any good suggestions. I may have to keep the mower mounted forever.
   / Mounting a mid-mount mower #2
If you turn the front wheels hard one direction, would there be room for the mower to roll under the tractor? That is how all the JD garden tractors I have had worked.
   / Mounting a mid-mount mower #3
If you have a loader, you can use it to lift the front wheels off the ground and let the deck slide under. Just don't put yourself under the tractor where you could be squished if something happens to the loader.
Aaron Z
Sounds like I shoul have tried that. It's just that that mower deck is so heavy and awkward it's hard to maneuver.
I did try that, but couldn't get front high enough.
   / Mounting a mid-mount mower #6
Aaron Z
Bingo!! We drove the front tires of our 1523 up on suitcase weights...worked great!!
   / Mounting a mid-mount mower #7
I pull my massey up on 2x4 blocks and that is high enough for it. I use an old tie down strap with a hook on the end and that makes it easy to pull the deck under the tractor. It surprised me how easy it pulls.
   / Mounting a mid-mount mower #8
Were you doing it on a concrete floor? That makes it easier than doing it in the dirt.
Actually started on grass, too hard to slide. Moved to asphalt, attached strap and was able to get deck under tractor. Wasn't easy.
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
7'x16' Utility Trailer (A50121)
7'x16' Utility...
