Mounting 430 to 990
   / Mounting 430 to 990 #1
yellowsocks93
Veteran Member
MN
John Deere 990 MFWD and a few others
Hi, today I tried to mount my 430 loader to the 990 today for the first time and could not get the latch plate over the front weight bracket about a quarter of an inch short. Tried everything in the manual. Then I put a jack under the latch plate and then it was almost on the bracket but it would not go on. Anyone have any ideas on what I am doing wrong? Thanks in advance.
Nick
   / Mounting 430 to 990 #2
I just put one on my 4310 and had the same problem. did you try to loosen the 4 big bolts(2 on each side? ) on the loader frame? it has quite a bit of adjustment. also put down preasure on the bucket and riase the front off the ground a bit. I ended up adjusting the lock rod a bit more and the smcked the front loader plate with a BFH an a block of wood and it went into place. After that it was easy to get on and off.
Yeah, I loosened the 4 bolts and was playing around with the latch plate rod but I was still short of getting the latch plate over the weight bracket. I did raise the front up with the dump function of the loader. I did put the new weight bracket on and everything. When you loosened the 4 bolts how loose did you have them? I had mine so I could turn the nuts by hand? Thanks.
Nick
John Deere 4455 (A50120)
John Deere 4455...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
