mott 72 flail mower roller rebuild
/ mott 72 flail mower roller rebuild #1
jonsstihl
Veteran Member
Quebec, Canada
Any one have any ideas on how to get a tie shaft out of a 6 foot roller. I managed to get the nut off the end but now the tie shaft seems to be a tight fit on the bearings and the roller is kind of big to handle. I have it soaking in 50-50 mix of diesel and atf but
I need to replace one roller bearing.
I got it off.
I used the rollers weight against itself. I threaded the nut on the end of the shaft then held the roller vertically and dropped it onto a thick steel plate I had set on the floor. That drove the other side bearing right out of the roller as well as the tie shaft. Now I need to use the same technique to get the roller bearing from the other side out of the roller since a 7 ft 1/2 inch bar used as a drift isn't working.
/ mott 72 flail mower roller rebuild #3
Sounds like you're wrestling a bear for a piece of salmon this morning. When my mott had that roller with the inside bearing (been changed) I used a slide hammer puller to get one of them out the other side fell out. That's a good design and last many years but my roller finally broke into and I had no luck welding it back together. Good luck..
2015 Ford Transit Cargo Van (A64556)
2015 Ford Transit...
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
Frontier QA Pallet Forks (A64126)
Frontier QA Pallet...
Hardee T-500-LP (A64126)
Hardee T-500-LP...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
