jeepster95
- Joined
- May 5, 2010
- Messages
- 4
i have an older Simplicity Landlord 3410 with the kohler motor, the motor was rebuilt by the dealership a few years ago so it runs great but after it has been running for a while when i shut it off it slowly starts to turn over again.
when i turn the key on/off it doesnt make a difference. after i disconnected the battery, i realized that it was the starter that is turning its not the motor running. so i proceeded to try to figure out whats causing this, i unhooked the solenoid from the starter and touched the negative terminal to battery and it started to turn over, this is with out the power to the starter. the starter is also a generator so im wondering if theres a short in the starter/generator or is there a problem in the black box mounted under the panel. is this black box a voltage regulator? why would i get a power bleed thru, this melted a bunch of wires so i replaced them to try and figure this out.
any help is appreciated
thanks
Dennis
thanks
Dennis
