More TL 2700 questions
   / More TL 2700 questions #1
Hoka Hey
I understand that the lever (bent rod) that is located below the ignition switch on the right hand side of the steering column, is a controll for the 3ph. When you select your operating height with the lever to the right of the seat, you then use the little lever on the steering column to raise and lower the 3ph to you preset height. Is this correct? Mine doesn't seem to work. What should I look for?
Also, there is an elctrical switch right below the ignition switch that I can't figure out. It looks just like the blinker switch that is located on top of the headlight switch on the left side of the steering column.
Where can I get parts for this tractor? Thanks.
   / More TL 2700 questions #2
I can supply you with parts & manuals.
   / More TL 2700 questions #3
For the short lever to work the handle on the right of the seat must be all the way down. The switch under the key is for the independent PTO. to the left turns pto off when 3 point raises, center is PTO off and right is PTO on.
Buck
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
Garbage Truck (A51692)
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
