More power from Z134 engine
   / More power from Z134 engine #1
sscott47150
1957 MF 50, 1964 cub Cadet
Will be overhauling my 1957 MF 50 with the Z134 gas engine this winter, and want to see if I can bump up the power, without breaking the bank.
Seems I recall a post in a form where some one posted ideas to get a little more power out of the engine.
He talked about the normal hot rod stuff, like matching ports to manifolds, and making sure every item is to spec.
Assuming I buy a kit with the slightly larger bore, that will help some.
Higher compression, upping from the current 6 to 1 might be a good idea, but not sure how much to remove from head surface to bump up to 7 to1, or maybe even 8 to 1.
I am asking if anyone recalls that post, or if there is experience out there I can tap into?
Long time MF owner,
   / More power from Z134 engine #2
Power costs money, how much you want to spend?
Wanting to keep it under 1K, so nothing like turbos in the plan.
Hoping to go from the rated 34HP to maybe 45-50 HP by upping compression, making sure everything is blueprinted.
Craftsman LT2000 Riding Mower **Does Not Run** (A50121)
Craftsman LT2000...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
