Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Just finished working on my seeder. As I ( and many of you ) suspected, it was a pre-lubed, 'non serviceable' model. The gearbox was 2 cast aluminum halves sandwhiched around the ptoshaft/seeder drive, and 2 captive seals / bearings. Seals were fine and bearings and gears showed no noticeable wear. Grease in it looked like it had had it.
Cleaned it up, and selected an area that was 3/8" thick ( sides and mounting areas were 1/2" ), and dimpled/drilled/tapped/packed and burped.
No leads at the seals or the zerk. Ended up using a 7/32 bit and a combo zerk "T" wrench that had a zerk socket, broken zerk extractor, and thread tap on it. Couldn't have been easier.
I will de-grease it and paint it this weekend.. cant decide whether to go back with it's oem red.. or to paint it nice ford blue. It would look fine in red hanging on one of my N's.. though if I did it in ford blue, it would give me an excuse to drive that shiny ford 5000 around the pasture a bit more...
Can't wait to get something to seed/spread now.
Great deal too.. 150$ plus the price of a pack of zerks.
Pto shaft is nicely un-stuck and greased and slides in and out freely.
In cleaning up the seeder I notice it has an adjustable opening on the bottom letting you choose 1/2/3 drop holes, as well as having the adjustable handle to open the seed gate.. etc... looks to be a great unit...
soundguy
soundguy
