More Newbie questions X585 Quick Hitch
   / More Newbie questions X585 Quick Hitch #1
danbike
Well the tractor is back with the Quick Hitch installed. Is it necessary to pull the QH in the spring when I reinstall the mower deck, or can I leave it on. Sorry if this is a dumb question, but I'm new to this tractor stuff.
Dan
   / More Newbie questions X585 Quick Hitch #2
i belive on the x585 you need to remove the quick hitch. The quick hitch uses the same connecting points as the mower deck. i think.. On my 455 you need to remove the quick hitch. Im not that familiar with the x series. sory
Don't apologize for giving someone the lead they needed to find an answer. Yes, the quick hitch would interfere with the deck mount. Thanks again.
   / More Newbie questions X585 Quick Hitch #4
I did put on my X quick hitch (X485 with the mower deck in place). It was a tight fit. However, the X series hitch is different from the 400 series hitch (the 400 will go on the X, but the X will not go on the 400). So, I don't think the old 400 hitch will go on the X series at the same time the deck is on.
When I put my X hitch on my X485, it contacted the threaded ends of the mower bail, but wiggled by. If the threaded rods ends were cut back (they're at least 1" too long) then I think there would be no conflict for the X hitch to go on the X series with the mower deck on at the same time.
   / More Newbie questions X585 Quick Hitch #5
I have an X585 with front Quick Hitch and 62" MMM. Yes they both can be installed and operated at the same time. Mighty fine piece of engineering!
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
2021 TAKEUCHI TL6R SKID STEER (A51242)
2021 TAKEUCHI TL6R...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
1240 (A50490)
1240 (A50490)
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
