I am finally close to pulling the trigger on a evaporator...spent the last few months scoping out used equipment and haven't had a lot of luck find good, used equipment, close to me and at a reasonable price (is that asking too much??).
Anyway, I first started looking at the $795 leader half-pint evaporator...15-50 taps. As cheap as I am, that still seemed like a lot of money....then my wife asks me, if you get that little one, aren't you going to wish you had a bigger one right away? she is probably right. I probably have 100 - 150 trees within 1000 feet of my house I can tap, and a whole lot more on the property (I would estimate 250 - 300 anyway)...
Anyway, so she is probably right, a 15-50 tap evaporator might be too small.....but then the question arises, what makes a 15-50 tap evaporator rated for 15-50 taps? If I had 200 taps, and a 15-50 tap evaporator, couldn't I just run it longer? where is the limiting factor?
If I was somehow able to loosen up my wallet to consider a leader evaporator in the 2x6 range (around $2500), there seems to be a few to choose from...any recommendations? what is a drop flue versus a raised flue etc. Looking for some recommendations.
And lastly, how much other "stuff" am I going to realistically need to add-on to the $2500 evaporator? If I realize that the $2500 evaporator is going to actualy be more like $3500 once I add on the required "options"...I defintely gravitate towards the smaller one.
Thanks all!
Thanks all!
