More lifting power
   / More lifting power #1
tucke022
Branson 2400
Anybody ever put stronger Hydro rams on a FEL to help with the lifting power?
   / More lifting power #2
Not a real good idea because they will alos have more bending power and it doesn't seem that there is a lot of extra steel in most FELs.
   / More lifting power #3
Yup, something will end up breaking. It'll also slow down the function.
   / More lifting power #4
Several things have been done... also, some changed out the cylinder to get higher lift. How much extra are you trying to get? What is your make and model of tractor? I bumped up the pressure on my tractor to get more lift, a few hundred extra...
There are some concerns about the tractor being design to handle the extra lift - extra stress, and what not.
Edit: I see your tractor Branson 2400, http://www.tractordata.com/farm-tractors/006/5/0/6502-branson-2400.html
It doesn't have your pressure listed, if you can find out what it should be... some times the factory settings are low. You'll need to get a 3-5000 psi gauge to check what it's set at. If you have a good dealer, you can have him check it too.
   / More lifting power #5
Most of todays compact trators have enough loader power to lift the back tires off the ground even when ballasted. Larger cylinders or more power is going to gain absolutly nothing if that is the case.'
And cylinders are pretty expensive just to get a little more lift. Not to mention it will slow down the speed of the loader as well.
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
