More KIOTI NX6010 Madness! Check out the last few projects with the Beast!
   / More KIOTI NX6010 Madness! Check out the last few projects with the Beast! #1
kapper
Vienna, IL
Branson 7845C
Here is my way of expressing that I am still digging the Kioti NX6010. DO NOT regret getting rid of the John Deere!
   / More KIOTI NX6010 Madness! Check out the last few projects with the Beast! #5
Thanks for the video on picking up a stone. I have three that need to be moved and all I can do right now is push them around the yard. It would appear I am not getting far enough under them. Also it appears it might help to dig out a bit in front of them before I go in to pick up the stone.
Based upon on line estimators all of them seem to be within the lifting tolerance of my tractor. I will have the weight box on the back for ballast... and keep the FEL low low low.
10-4,. Another guy suggested pallet forks if you have them, which I do, but I didn't think of trying them. Yes, you've got it; LOW, low, low! lol Good luck!
   / More KIOTI NX6010 Madness! Check out the last few projects with the Beast! #7
I have a similar tractor and operate on terrain much like yours. I use chains, forks, grapple and decided a couple of years ago the added cost of steel wheel weights was well worth the money. Not saying what you're doing won't work, just what helped me. Interesting videos.
   / More KIOTI NX6010 Madness! Check out the last few projects with the Beast! #9
No forks right now. FEL and bush hog are all the attachments I have at the moment. WE are in the process of building a barn and will have 10 horses here soon enough. I am sure more attachments to follow.
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
