More is not better with a hydro
   / More is not better with a hydro #1
btolle
Platinum Member
Jasper, Texas
Kubota B7510HSD
I was really paying attention to my use of the hydro pedal yesterday while moving a lot dirt up a hill. I still have to overcome the tendency to push harder on the pedal when the RPM's start to drop going up the hill but it works better if I back off a little bit. The RPM's stay up and it easily pulls a hill it would lug on when I had the pedal all the way down.
With the loaded rear tires on the B7510 I could carry a bucket full of wet dirt and pull the box blade till it was overflowing at the same time. As long as I kept the RPM's up it kept moving nicely. If I mashed the pedal harder the RPM's would drop and speed would slow. I could actually bog the engine down to where it nearly died if I kept the pedal to the floor.
These new fangled machines take some getting used to.
Another valuable lesson learned from this forum!
Bill Tolle
   / More is not better with a hydro #2
Bill I remember the day they rolled our TC-40D off the delivery truck. Once the dealer had finished giving me instruction and had gone down the road it didn't take me 5 minutes to jump on that puppy and fire it up. I immediately threw it in high range and started up a steep hill on the property. As the RPMs started to decline I stepped on the hydro pedal a little harder until finally the NH just stopped in its own tracks. /forums/images/graemlins/mad.gif I swear I could hear the relief valve singing to me.
Since it was a new tractor and I had no previous experience with hydros I immediately thought that I must have made a huge mistake in purchasing the hydro transmission over the gear transmission.
Once I read the operators manual and realized that with less pressure you get more power I started to get a grasp on the whole hydro concept. I've really enjoyed it ever since.
Just try and take my hydro from me today, it just isn't going to happen without a fight. /forums/images/graemlins/grin.gif
   / More is not better with a hydro #3
Bill, this goes against what everyone has been saying, but I never experienced this. As I recall, right from the get go I was backing off on the pedal. Perhaps it came from the many years of operating a Bobcat skidsteer where the same applies only with your hands. A friend of mine used it and I watched him use it to move a pile of dirt. His first to loads killed the engine, after that he had it down. My brother in law is another story. More pedal means more power right? No matter how many times I tell him, it won't sink in. I'm beginning to wonder if HST is something everyone can learn in one sitting?
   / More is not better with a hydro #4
now I know, don't know if I thought about it or not before. I just add more rpms if it is bogging down, bw
   / More is not better with a hydro #5
<font color="blue"> now I know, don't know if I thought about it or not before. I just add more rpms if it is bogging down, bw </font>
It's a little like flying a fixed wing plane. Yes you can increase engine RPMs for more airspeed or simply drop the nose and the speed will come up quickly automatically. With the hydro you can also increase RPM's but it's easier to just come back on the pedal pressure a bit and the RPM's will take care of themselves.
   / More is not better with a hydro #6
That's mistake number 1 and I'd bet 90% or more of hydro owners have done the exact same thing by usind the hydro pedal as a "gas" (diesel) pedal.
It's all about applying torque to the ground where less (pedal) means more (torque to the ground).
   / More is not better with a hydro #7
Cool, you really do learn something every day.
Now, whether I remember it or not is another issue.
   / More is not better with a hydro #8
Pineridge: The analogy is even better with a constant speed prop. There, adding power (throttle) increases the pitch of the propeller and thus increases thrust. You can then translate the increased thrust, depending upon nose attitude, into increased airspeed, or climb, or some combination of the two. The variable pitch Prop is sort of the equivilent of the continuous hydro tranny.
The difference is that with a hydro tractor, you set your rpm and then, for that rpm level, you can infinitely vary the apportionment of that level of engine output between speed and work power for that setting. The hydro pedal, as I understand it, increases the gear ratio and thus the speed of the driving wheels the more you depress it. The trade-off is that the more speed you call for, the less working power you have.
BTW, what do you fly? I used to have a Mooney M-21 (4 seat, retractable gear) and before that, a Cessna Skyhawk.
Someday, perhaps I'll get another. /forums/images/graemlins/grin.gif
   / More is not better with a hydro #9
</font><font color="blue" class="small">( Bill, this goes against what everyone has been saying, but I never experienced this. As I recall, right from the get go I was backing off on the pedal. Perhaps it came from the many years of operating a Bobcat skidsteer where the same applies only with your hands.)</font>
Absolutely, the same concept on skid steers, the brain is ready for it. Those who may have just driven cars, bikes, where the basic rule is 'when in doubt, gas it', it's more natural to treat the hydro pedal like a gas pedal. Takes a bit to unlearn that.
   / More is not better with a hydro #10
<font color="blue"> BTW, what do you fly? I used to have a Mooney M-21 (4 seat, retractable gear) and before that, a Cessna Skyhawk.
</font>
MadDog I trained in a Cessna 150, and flew weekends in a Cessna 172. I tried to outrun a nasty thunderstorm one hot summer day years ago and didn't make it. I actually ended up taking a real wild ride through it and at that point I came to the conclusion that: I would much rather be on the ground wishing I was in the air, then in the air wishing I was on the ground. /forums/images/graemlins/shocked.gif
I have not flown since, I'm grounded......
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A53843)
RIPPER ATTACHMENT...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
5TH WHEEL TRUCK TOTE (A53843)
5TH WHEEL TRUCK...
