more good news
   / more good news #1
kubotaman68
northeast kingdom vt
kubota 2250 loader woods bh 7500 , gehl 4640 skidsteer
Broke my own rule and borrowed my cousins case skid steer to unload a truck on a remote site my stuff was 80 miles away his was 5 mins away . Well she ate a valve I believe was using it for 10 mins let it run for 20 mins before getting in it talking to driver . AND then it started rapping and smoking
YIPPEE more expenses /forums/images/graemlins/frown.gif I am not taking it back broke . Anyone know if my diagnosis is correct ? It was running about 3/4 throttle it started rapping intermittantly and by the time I got it shut off it was constant
   / more good news #2
There are so many things that could cause a noise I wouldn't put much money on it being a valve, even though it could be. My little tractor did that once. Convinced me it was toasted. I found out it was caused by hydraulic oil leaking into the crankcase. The excessive oil level caused a nasty knocking noise combined with a lot of smoke. I changed the oil, fixed the leak and it ran good as new.
Good luck with yours.
Tom
   / more good news #3
Kubotaman,
That is one really bad day /forums/images/graemlins/frown.gif I feel your pain! Many, many years ago when I first became a homeowner, I borrowed my neighbors splitting maul to split some wood. The very first swing, I overshot the log and took the head clear off /forums/images/graemlins/confused.gif Went down to the hardware store and promptly bought two brand new mauls. It was an inexpensive lesson to learn /forums/images/graemlins/grin.gif
On your problem, a bit more complicated, Im not sure that I share your view on the valve. But in any event good luck with the outcome!
scotty
   / more good news
well my cousin called they took the pan off looks like a rod bearing $$$$$$$$$ un known /forums/images/graemlins/frown.gif
   / more good news #5
Do you know for an absolute fact it's the engine? Possibly a hydraulic pump knocking? Could be a hundred things, although it could very well be that valve you're talking about.
But I'm afraid you're going to be spending a few pesos anyway.
   / more good news
yes its definitely the engine they took the valve covers off all the valves are moving , took the pan off his hired guy is very mechanical he is leaning toward rod bearing or piston. but i agree on the bueno peso's /forums/images/graemlins/mad.gif
   / more good news #7
I was thinkin rod bearing /forums/images/graemlins/frown.gif They will have to see how bad the crank journal is, if its scored to any degree they will have to pull it and grind /forums/images/graemlins/frown.gif Gotta grind all the rod journals to do it right IMHO, and then get new bearings.
Could have been worse! You suck a valve and you got real problems then /forums/images/graemlins/grin.gif
scotty
   / more good news
You know in the world of shoulda coulda woulda, i shoulda just told the driver to drop it off at his site and I coulda picked it up later. I woulda been able to avoid this whole mess , and woulda saved a few hundred bucks /forums/images/graemlins/mad.gif
   / more good news #9
Kman,
I wish I had relatives like you. /forums/images/graemlins/cool.gif Mine tend to return things, (If they even do that ), in whatever condition they were in when they last used them. And just because it didn't work when I went to use it, doesn't mean they broke it.
Also, thanks for the post on the piano move. I will definitely be using a piano mover in 3 weeks. Especially with the afformentioned family members helping me to move the rest of my stuff.
Tiny
   / more good news #10
Sounds like it was an impending failure no matter who was using it so maybe you should help fix it not flip the whole bill for 30 mins of work.
1986 ASPT 30ft Pole S/A Towable Trailer (A51692)
1986 ASPT 30ft...
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
