More Beginner MIG Questions
   / More Beginner MIG Questions #1
mmranch
Crested Butte, CO
TYM T603
Nozzle Gel.
I have a tub of Hobart nozzle gel which is blueish in color. It works fine but I'm wondering what the consistency of the gel should be for dipping. My shop is pretty chilly in winter (until I crank up the heat). The gel is very thick and not liiquidy. I'm wondering if it's thick because of the chill and should be more fluid for best use? If I dip my MIG gun nozzle the gel seems too thick and I get way too much on the nozzle which I have to clean off a bit before use. Also, is it OK if the gel goes into the contact tip with the wire?
Wire Tip Ball
When I am done with a weld, my wire tip has a small ball of melt on it. I have then continued to begin the next weld. Is it best procedure to cut off the small ball before beginning the next weld or is it OK to leave it and start the new weld?
Thanks!
   / More Beginner MIG Questions #2
My last MIG gun pretty much required the use of gel, especially if I was welding overhead. I can't think for normal steel welding that the gel would affect anything regarding your quality of weld. When your nozzle is hot, dip it in the gel and it will coat the nozzle and tip. I suppose that a person could pack enough around the tip to temporarily stop the gas flow. That will last until it melts. I still use the gel. Especially if I'm working on things that I couldn't clean the rust and scale off or didn't care to. I don't worry about starting w/ fresh wire for what I do. If you need the extra strength, you will need to do the prep. You'll find if you pay attention to your welds and spatter that you will be an accomplished welder in no time.
   / More Beginner MIG Questions #3
I've sold Nozzle dip my whole career. Never tried the gooey crap.
   / More Beginner MIG Questions #4
ive never opened the can of it i bought about 10 years ago. but seeing as im welding up 20 pieces of 8' x 5' wraught iron handrails right now, i think ill try some when i head back to my shop on Wednesday. the guy i making these for handed me some crappy rusted pipe he bought 2 years ago and left outdoors. his son has sanded it all down, but welding this material is challenging to say the least. not my prettiest welds. but there going in strong. well sandblast them 2 times and do a hammered powder coat, they should be ok, i hope.im not used to working with pitted steel, especially the light weight kind.
i never bother cutting off the little ball of slag either. unless too much is showing past the tip. i carry a cutter in my back pocket just incase.
   / More Beginner MIG Questions #5
+1 I don't bother with the ball on the end unless it's really big and/or deformed. Just keep welding. As for the gel, sometimes I use it - I'll just dip the nozzle in and weld. I've found that with MIG I need clean steel so I'll either sandblast it or use a flap sander on an angle grinder to get to clean metal. If I need to weld thru paint or rust, I'll use my stick welder.
   / More Beginner MIG Questions #6
The nozzle gel will help reduce the amount of berries inside the nozzle. Which will help reduce the amount of time you spend scraping it clean every so often. It will also help the wire from sticking to the tip. When starting off cold, run a 2" or so bead on some scrap to get the tip hot and gently dip it into the gel. If you have excess gel in the nozzle, just pull the trigger real quick and your shielding gas will blow out the excess. IF you are using a shield gas that is. B.
   / More Beginner MIG Questions #7
I just use PAM (cooking spray) ... It's canola oil, it works.... Never used nozzle gel in the years I have been MIG welding...
Thanks to all for the ideas!
I think when I crank the shop heaters up I will put the gel tub in front to see if it loosens the gel up a bit. The hot nozzle is probably the best solution. And I won't worry about the small tip balls and just resume welding.
The gel does work great (and so does Canola oil... I already had some of that for spraying around the weld zone). I accidentally started my first MIG welds and didn't use the gel. I laid down about 8 beads and then remembered and looked at the nozzle. It was already getting pretty dirty so I cleaned it all off and then used the gel and the nozzle stays so much cleaner.
Thanks again.
   / More Beginner MIG Questions #9
I always had a hot nozzle so the excess always ran off.
   / More Beginner MIG Questions #10
I dip the hot nozzle in a large jar of Vaseline. It seams to work just fine, but I'm just a part time hobby welder.
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
UNUSED FUTURE ECA63 ARTICULATED BRUSH CUTTER (A51248)
UNUSED FUTURE...
2020 COLOMBO TM LOT IDENTIFIER 193 (A53084)
2020 COLOMBO TM...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
TRAILER CHASSIS (A51247)
TRAILER CHASSIS...
