More about wheel motors and towing from White
   / More about wheel motors and towing from White #1
catsco
Colorado
PT425
A little long, but interesting. To some people.
On 4/15 in "About to take the PT plunge", KentT had a link to the White CE and White RS hydraulic motors.
I looked at the website and saw this; not sure what the add'l. cost is, but would be nice to have to move the PT when towing is needed.
I suppose there are (at least) two downsides:
1. The parking brake would REALLY have to be used, and work well.
2. If the motor stalls going up or down a really steep hill, a person might find out that 8mph is not really the top speed of a PT-425!
The links are:
White CE info -- designed to be wheel motors:
CE Motor [400, 420, & 430 Series] : White Drive Products, Inc.
White RS info -- designed to be inexpensive:
RS Motor [200 Series] : White Drive Products, Inc.
The declutch info reads:
The declutch or (ASCII charcter unknown) option, available on the RE and CE Series motors, has been specifically designed for applications requiring the motor to have the ability to freewheel when not pressurized. By making minor changes to internal components, the torque required to turn the output shaft is minimal. Selection of this option allows freewheeling speeds up to 1,000 RPM depending on the displacement of the motor and duty cycle of the application.
To enable the motor to perform this function, the standard rotor assembly is replaced with a freeturn rotor assembly. Next, the standard balance plate and endcover is replaced with a special wear plate and ported endcover. The wear plate features seven holes that connect the stator pockets to each other. The ported endcover features a movable piston capable of sealing the seven holes in the wear plate.
When standard motor function is required, pressure is supplied to the endcover port, moving the piston against the wear plate. This action seals the seven holes allowing the motor to function as normal. However, when pressure is removed from the endcover port, the pressure created by the turning rotor assembly pushes the piston away from the wear plate, opening the rotor pockets to each other. In this condition, oil may circulate freely within the rotor and endcover assemblies, allowing the rotor assembly to rotate freely within the motor.
This option is especially useful in applications ranging from winch drives to towable wheel drives. Depending on the valves and hydraulic circuitry, operation of the freewheel function may be manually or automatically selected.
Hope someone finds this useful.
Regards,
Mark H.
   / More about wheel motors and towing from White #2
They must use a motor similar to this on the brush mower. It takes a while to spin down after you switch off the pto and I don't think there's a clutch between the motor and the blades.
That certainly makes sense. If the blade could not coast down, there would be tremendous torque from it if it stopped suddenly.
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
20" HYDRAULIC CYLINDER (A51248)
20" HYDRAULIC...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
UNVERFERTH 210 LOT IDENTIFIER 159 (A53084)
UNVERFERTH 210 LOT...
CHAMPION 7500 WATT GAS GENERATOR (A51248)
CHAMPION 7500 WATT...
