montana trash
   / montana trash #1
COYOTEMAG
opleousas , louisiana
ford 9600, 7600(2),6600,5000(2),4000,3000,545 indudtrial
Thought I got a good deal. 2 things; Thats what I get for thinking; and; if its seems to good to be true it usually is.
With that said. I have a 34hp model 3840 Montana. The pto turns and the hydraulics work fine , but the tractor wont move. I havent had the courage to tear into it yet. Anyone out htere experience this before.+
   / montana trash #3
:welcome: from Ohio
   / montana trash #4
Check to make sure the range selector and the gear shifter are both in gear AND the forward/reverse shuttle is in gear. Tractordata says 12 forward and reverse - it must have either two ranges with six gears + forward and reverse OR three ranges with four gears + forward and reverse. I've had my Kubota for nearly two years and I still forget to get all three in the right combination from time o time.
Then check the clutch adjustment. Then "tear into it"
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
