Montana (FramTrac) 545 Engine Skip
   / Montana (FramTrac) 545 Engine Skip #1
jetjocka7
Ashford, AL
Montana (FarmTrac) 545DTC
42 HP Engine. My tractor started skipping and losing power after about 5-8 minutes - finally found some good advice - removed fuel cutoff/screen from bottom of fuel tank.
Found red paste like substance had caked up the screen, restricting flow of fuel. washed out cutoff valve and fuel tank. replaced primary fuel filter which also had some of the pasty stuff visible inside (Use Wic 33472 fuel filter/water separator; keep your drain plug and install it on new filter before filling with fuel and installing.) Secondary filter appeared to be clean so I put that filter on the primary side and the new one on the secondary side.
Tractor cranked right up and ran like new- no skip. It was starving for fuel because of the restricted flow in tank.
   / Montana (FramTrac) 545 Engine Skip #4
Welcome to TractorByNet!
We moved your thread to the Montana forum. :)
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
CATERPILLAR 325FL CR EXCAVATOR (A51242)
CATERPILLAR 325FL...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
