Montana 5740c parking brake light stays on.
   / Montana 5740c parking brake light stays on. #1
keiken01
LG Montana 5740c / Agco Allis 4660
I have had this tractor about 2 years now. Got it used from a fella that also got it and used it for mowing about 2 years and sold to me with around 300 hrs. I had to have the font end rebuilt as the front wheel right literally fell off. After $3500 and 12 weeks, I got it back and all was working fine, but and after a couple weeks the brake light is staying on. I'm guessing there is a switch or relay somewhere that got removed or is there something else I should be looking for
Thanks!
   / Montana 5740c parking brake light stays on. #2
Follow the brake handle and associated linkage. There will be a bracket with a spst switch attached. Probably just need the switch adjusted slightly away from the device pushing on the plunger. I had a similar problem on my 6530 and it didn't take but a few minutes to move the switch.
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
