Montana 5740 Grinding in Reverse
   / Montana 5740 Grinding in Reverse #1
Zurpro
Calgary AB
montana
Recently when you shift into reverse and start moving there in a grinding noise from trans area - noise goes away if you hold forward/reverse lever back ! Is there an adjustment on the lever ? Could not seem to locate the rod that goes under the cab to trans !
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
Genie GTH-644 (A50490)
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
