Montana 3040 Hydraulic warning light
   / Montana 3040 Hydraulic warning light #1
orwinlaw
Montana 3040
The hydraulic warning lamp on my Montana 3040 has come on. I replaced the hydraulic filter and replaced the hydraulic oil but the lamp remains lit. Does anyone have any idea what the problem is? Is there something that needs to be reset after I changed the filter?
   / Montana 3040 Hydraulic warning light #2
I do not think there is anything to be reset, I have never had to and changed the filter 2 times now.
I would be looking at the wiring for the switch that turns the light on. The switch is right by the filter and the wires are kinda in a bad place for stuff catching on them. If you unplug those wires will the light stay on? If it does the wiring is grounded or contacting eachother somewhere. If id does not stay on I would guess the switch is bad.
You might want to try posting this in the Montana forum.
Thanks for the tip./ I will check it out
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
2013 RAM 4500 (A50323)
2021 Ford F250 4X4 Service Truck (A52377)
2021 Ford F250 4X4...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2015 FREIGHTLINER...
