moisture in manual Trans.
   / moisture in manual Trans. #1
marty
Bronze Member
Mid West
Boomer 33D
On manual transmissions with the H/L and 5 gear selection levers, has any one figured out how to eliminate moisture from getting into the transmission? Both units we have have this problem and we have to change them prior to winter or they will be froze solid when the temperature drops below zero.
   / moisture in manual Trans. #2
I would change the two rubber boots to start with...
John,
Are these boots located just on top of the lid? I am assuming that one would have to remove the top lid to remove the shifting sticks. Have you ever done this and how hard is it?
   / moisture in manual Trans. #4
Marty, your problem I don't believe is unique to you. We get it bad in the northeast on all types of transmissions. There are different oils that absorb more water in the oil. You might need to go to changing the oil every year.
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2015 Freightliner M2 106 Ambulance (A50323)
2015 Freightliner...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
ASSET DESCRIPTIONS & CONDITION (A52577)
ASSET DESCRIPTIONS...
