moisture in hydrolic fluid/trans oil
   / moisture in hydrolic fluid/trans oil #1
jimmoore
Platinum Member
Augusta, AR
05 CASE IH D35 W/FEL
Does anyone know of any type of anti-icer for hydrolic/transmision fluid/oil? It was 14 degrees here this morning and I fired the tractor up to push some brush. The 3ph was slow to raise and I
thought it was just cold, I drove into the woods and lowered the blade and it would not raise again, I sort of thought that there was ice in the control valve so I parked the tractor into the sun and did some chain saw work, went back in about an hour and started up again and the 3ph worked perfect. The drift is, I think I have a slight bit of moisture in the fluid from condensation, and wondered if someone made and anti-icer like you use in diesel fuel?? jim
   / moisture in hydrolic fluid/trans oil #2
Jim, Have used Sea Foam for this in older tractors, have not had a problem with the new one. Buy it at any auto or farm store. Also good for deisel fuel deice and gel situations. gary
Thanks for the info Gary! jim
VOLVO 12.1L FRONT CLIP (INOPERABLE) (A53843)
VOLVO 12.1L FRONT...
2019 CATERPILLAR  323FL EXCAVATOR (A53843)
2019 CATERPILLAR...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
