def38
Platinum Member
I have this Howse box blade. It uses slotted ripper shanks that are held in place with jam pins, a poor design IMO. I wish to modify the shank mountings by welding ears onto the square steel tube that the shanks mount in. The ears will be located on either side of the shank mounting slot. The ears will be drilled to receive pins to hold the shanks in place. Further, I'll need to drill the shanks to receive the locking pins.
Question is, are those shanks too hard to be drilled? I'll use a hand held electric drill (3/8 chuck) and a cobalt bit to poke 15 holes in the 5 shanks and 10 holes in the ears. The hole size will be 1/2" dia.
Next, are any of you located in Blount or Jefferson County, Alabama and have welding equipment? I'll pay any reasonable fee for welding (I'll trailer the box blade to you).
Thoughts and comments welcomed.
