pequeajim
Platinum Member
This is a question for all of you as well as Jack from Robin?
There has been discussion about the rating of the Robin engine for use up to 20-25 degree slopes. After this, there is a possibility of starving the engine of oil?
Correct me if I am wrong here, but the explaination is because of the location of the pickup for the oil? If the engine is tilted too far away from this, then it could draw air instead of the oil?
Again, excuse the dumb sounding comments, but if this IS the case, what would be the correct solution? I guess you couldn't use multiple pickups for the oil as at any point, one of them will be drawing air?
These are all questions, not opinions. I know with my giant scale gasoline airplanes, we use a clunk system, (a weighted clunk on some tubing) No matter which way the tank is turned, gravity pulls the clunk and the fuel to the same spot so that you do not draw air.
I'm not suggestiong this for our tractors, but am wondering how this limitation is solved on others?
