Modifying a Tiller for better seed bed prep
   / Modifying a Tiller for better seed bed prep #1
TractorDale
fairfield, ct
TC 29DA
Wonder if the blades on my new KK tiller could be safely modified to make it work more like a harley rake or pulvarizer. My thought is to drill and tap each blade to accept one 2" long or so point that would break or bend away before the blade bent on a larger rock or whatever. The points could be easily unscrewed to return the tiller to original. Points could be made from 1/4 or 3/8" bolts. Gauge wheels could be easily added as well. Don't have the unit yet so not sure how much clearance exists between blades and housing.
I usually manage to void waranties anyway.
Thanks for your thoughts.
Dale
   / Modifying a Tiller for better seed bed prep #2
I'm not sure what you are trying to do here, Dale. If you don't have tiller yet, I would wait til you have and try it. My tiller makes a great seed bed, no mods. Yours may do the same. Of course it depends on the soil type, but yo may be thinking of an unnecessary mod.
Keep us informed.
   / Modifying a Tiller for better seed bed prep #3
The harley rock rake works at an angle to the tractor, you might have trouble getting the tiller to do that to make a windrow. Hitch modifications would be in order and probably extra gauge wheels to carry the machine at the proper height.
Areas of my yard are compacted beyond the point at which grass will have a decent chance. Besides the tiller, I ordered a box blade that might help the situation.
Thanks for your thoughts folks. When the ground is somewhat moist will get the tiller (unaltered) working.
Dale
   / Modifying a Tiller for better seed bed prep #5
an aerator is designed to reduce compaction in lawns promoting good root grouth etc. (among other things)
   / Modifying a Tiller for better seed bed prep #6
Unless to have time,a welder and a good scrap pile...you might be time and money ahead just to rent a powered aerater for a day or two.Cheap pull behind star knife models can be purchased for about the cost of a rental.
Loflin 72in Quick Attach Skid Steer Grapple (A51573)
Loflin 72in Quick...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2013 John Deere 824K (A53472)
2013 John Deere...
2012 John Deere 7230R (A53472)
2012 John Deere...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
