nikdfish
Veteran Member
I had the JD folks pick up my 3038e to check out the loader cylinders (things seem to be leaking down a little too quickly for a machine < a year old) & decided to use this down time to make a little change to the EZ-Hitch I got from Carter & Sons.
I do like the EZ-Hitch, it has made hooking up much easier as a one man task. One peeve, though, has been their tendancy to flop to one side or the other after the plastic rings provided to keep them upright wore out/got mashed up. It has occasionally sprung a lynch pin on the implement draw pin.
On each EZ-Hitch I drilled & tapped 4 holes for 3/8" bolts. I intend to use 3/4" long bolts to center the hitch on the arm. As the EZ-Hitch is 2" across and the arms are 5/8" thick, the bolts should snug up pretty close. I figure a little Locktite should keep things in adjustment.
We'll see after I get things back together ...
Nick
Nick
