modern chain saws
   / modern chain saws #1
WTA
Platinum Member
Have any of you recently bought one of the little low priced chain saws and gotten really ticked off with it? I sure have. I did some research on the net yesterday on the particular model I got and was shocked to hear how so many other people were as frustrated as I am with the same model. In fact I couldn't find one good thing said about it except in the store reviews from places that were selling them. Makes you wonder.
I had an old Poulan that was nearly 20 years old till last fall when it finally wore out. I went out looking for another one but couldn't afford much so we got one of the 100 dollar ones from wally world. It has a 14 inch bar and was the same brand so I figured it must be good. The first time I used it it cut through limbs like they were butter. When I was done for the day, I cleaned it up, sharpened the chain and put it away like I always did with the old one. Then I had to use it again to clear a tree off our driveway that was blown over about a month later.
I filled it up with fresh oil and fuel and went to cutting and every time I put it down it would shut off. What a pain that is to restart the motor every time I pick it up.
I looked at the adjustment screws and they are some proprietary design and even with 20 years experience as a mechanic on everything from aircraft and steam engines to modern car engines, I couldn't come up with a tool to adjust it without firing up the lathe and making one. That was my first big disappointment with it. I wasted about 2 hours that day making a special tool and adjusting the carb. I did that after calling the customer service number in the owners manual and getting told they did not sell the tool or the shop manual for it. They said it had to go to an authorized service center. Also that since I did not fill out the warranty card that it was out of warranty so I'd probably be paying for it. Yeah right. I'm not spending more to have something fixed than I paid for it in the first place. I just junked my wifes car for that reason.
I got it to idle ok and went back to work but I have to say that idle adjustment screw is touchy. It's either too slow or its so fast it turns the chain. There is no in between no matter how precisely the mixtures are set.
I finished up the job that day, did my routine of cleaning it, sharpening the chain and putting some fuel stabilizer in the gas and put it up untill yesterday. About 9 months or so.
I had to drop a big honey locust in the yard and got it out. At first it was hard to start but I got it finally. I didn't readjust anything and it was running as close to perfect as it gets when I put it up last time. This time it wouldn't hardly cut through a 2 inch thick limb without bogging down. My chain was very sharp too. The high speed mixture was off I figured. I spent another 2 hours looking for that special tool I had made and readjusted it to work on the high end and then the darn thing wouldn't idle again.
Now I have rebuilt well over a thousand carburetors in my time and I know what I am doing. This thing is a piece of trash! I've done carbs on antique tractors, motorcycles, 2 cycles like this, hot rods and all kinds of stuff and I have never seen one that wouldn't get through one use without needing to be adjusted.
That tree was only 15 feet from my house and between it and another building so I was up in the thing with a harness on limbing it from the top down untill there was no danger of it falling on something. Imagine my frustration having to restart it every time I got done with a cut while hanging on to the tree in a harness 30 feet above the ground.
When I had to restart it probably for the fifth time I threw it as far as I could across the yard. Then I went in to tell my wife we're going to the store to buy a real saw! I came home with the biggest Husquevarna saw I could get. It's a 20 inch with almost 4 HP and is very nice. I don't care if it's a little heavy. At least it's working. The reviews all seem good on them and I don't think I'll have a problem with it.
I will never buy another cheap tool as long as I live! That little Poulan was a piece of junk!
   / modern chain saws #2
If it was roughly a month old, I would have returned it. Wal-Mart is easy to deal with on returns. My el-cheapo Poulan WildThing saw is 3-4 years old and still starts and runs well. I keep the chain sharp but, I don't do anything special other than that, old gas, etc...
I'm a infrequent saw user so it was (and is) good for me, so far anyway. my father-inlaw said I needed a saw and to go pick one out. I didn't see the need for an expensive one, so that was what I picked.
Maybe I've just been lucky.
   / modern chain saws #3
After Katrina, the cheap Poulan was the only saw I could find to buy and I had to travel 180 miles roundtrip to get it. I was cutting trees 14 hours a day for months. The Poulan would last about a week or two then I would bring it back to Home Depot and exchange it for a new one. I went through about 6 of them plus a McCullough in 4 months.
My last one is barely running now and is out of warranty so I am also looking for a new saw.
And the only reason they even ran as well as they did was because I followed some advice from a friend who has repaired chainsaws for 50 years. He said to make sure to use the recommended oil and mix it EXACTLY. Even a tiny difference in the mix will require carburetor adjustment.
   / modern chain saws #4
I bought 2 Stihl saws 5 years ago with many uses.No problems except a fuel line split.They cost more but reliability is worth it to me.
   / modern chain saws #5
WTA, I use to buy the cheap trimmers. Have been out in the heat trying to get the line to feed , trying to keep the thing running. Threw the thing away & bought a commerical grade string trimmer & have lived a happier life since
Buying cheap some times just ain't worth it
   / modern chain saws #6
I bought a husky from TSC a while back and probably have a good 15 hours on it and am really impressed.
   / modern chain saws #7
It's worse in California...
My 35 year Craftsman 14' limb saw with Power Sharp finally wore out. I replaced it with a light commercial Echo with prime start 3 years ago.
The little 14" Echo has performed great, I paid $209 for it.
Last year I went back to the same Mower shop to buy two more for my brothers. The shop said the saw had been redesigned to comply with the new CARB standards and they have had starting and idle complaints from customers. The replacement saw no longer has the primer bulb. The shop recommended Stihl for more money.
CARB stands for California Air Resources Bureau.
I also learned that most of the inexpensive saws are mostly plastic and are rated for a 50 hour service life.
   / modern chain saws #8
I'm a firm believer that a little extra money spend on a quality tool pays back dividends in spades. However, I have a Homelite Timberman 18" that I paid $120 for at HD. It's about a year old now and (I'm guessing) roughly 25 hours of cutting time on it. I've cut down roughly 40 trees and bucked them all into firewood.
If it died tomorrow, it was worth the $120.
I think my next saw will be a higher quality one, but only because I might appreciate joy of ownership more.
   / modern chain saws #9
I've got a Homelite20" also bought at Home Depot for about the same price.
So far it has been great. I've cut alot with it. Of course Homelite now isn't the old Homelite from the past...it is a Chinese company now owned by Techtronic Industries of Hong Kong since 2001!
   / modern chain saws #10
For $400 to $500 you can get a Stihl or Husky that will last 20+ years, start every time, and work like a dog. It's just not worth the frustration and hassle to do anything else.
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
