Model 60 steering.
   / Model 60 steering. #1
fsawer
Luther, IA
I have too much slack in the steering approx., 3/4 turn of the wheel. There are no shims in the housing. Is it possible to have the housing machined to correct the problem?
   / Model 60 steering. #2
Your housing isn't likely the problem, it is a worn worm gear or sector. It could also be the bearing at the end of the steering shaft is worn out allowing the shaft to move in and out. You mention checking for shims, have you also had the cover off the top of the pedestal to see how the gears look? I'm guessing that you don't have power steering
2008 Ford F-450 SD 4WD Pickup Truck (A53117)
2008 Ford F-450 SD...
Deere 333E (A50123)
Deere 333E (A50123)
1838 (A51248)
1838 (A51248)
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
