Model 5500 Power steering problem
   / Model 5500 Power steering problem #1
Jim B
Dixie Inn, Louisiana
2005 Mahindra 5500 2WD
I am having a problem with my power steering. It seems to be floating and the steering wheel is moving. Has anyone had a similar experience and know what the problem could be? I've checked the fluid level and added some fluid I only have 62 hours on it.
   / Model 5500 Power steering problem #2
Jim
I believe what you are talking about is the M on the steering wheel doesn't end up in the same position. That is normal on any tractor that has 100% hydraulic steering. All of the Mahindra tractors have 100% hydraulic steering so that is normal operation. I hope that is what you were referring to and you don't worry about it any more.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia NY
585-343-0770
Thanks for the good information about the steering. I slept much better last night. :)
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
Unused Delta Crash...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2018 John Deere 333G (A47384)
2018 John Deere...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRA (A51243)
2012 MACK PINNACLE...
