Model 5005
   / Model 5005 #1
motorjock
Bronze Member
Tx
NH TN75DA
My uncle has a 5005 and apparently the hydrolic filter is difficult to locate. Can anyone tell me where exactly it is so that I can pass it on to him. Thanks in advance
   / Model 5005 #2
I have a 5005 and there is no "filter", just a screen on the return line from the resevoir to the pump. The return line is on the right side of the tranny. There is a split in the line (on mine anyway) right at the tranny so you can split the line, loosen the bolt on the resevoir just below the seat and remove the screen. Be careful when you put the line back together. I had a piece of the rubber peel off inside the line and stop it up. Cost me a hydraulic pump. You will want to drain it first (the plug is in the back below the check plug) or you will have a melluvahess.
Hope this helps
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
20ft Anderson Trailer 14K (A52128)
20ft Anderson...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Rhino 484 (A50322)
Rhino 484 (A50322)
