Model 450 Snowblower repair and tech info needed
   / Model 450 Snowblower repair and tech info needed #1
mdrohman
MN
Cub 1872, Lesco (Ford CM224), Jacobsen "Out Front Commercial"
Hey everyone,
First post in the cub section. I have a 1872 with a model 450 snowblower. During the last 5" snow we had my augers stopped spinning so I got my tools and spare shear bolts and went out to the tractor to find all the shear bolts in tact. Not good.
Using this website:
Parts and Diagrams for Cub Cadet 450 45" Snow Thrower
I was able to find the part number for the gear (and cheaper prices). It turns out this gearbox and gear are used on many small snowblowers - 28" walk behind models. No wonder it stripped on a 45" (also I will be installing the shear bolts much looser from now on).
Amazon.com: Snowblower Worm Gear - Replaces MTD 717-1425 & 917-1425.: Patio, Lawn & Garden
Gear Worm LH MTD 917 1425 717 1425 Snow Blower Snowblower Parts | eBay
Questions:
1) These gears seem to come in aluminum (steel?) and brass or is that just an optical illusion on the web sites?. What would be better/stronger?
2) The driving gear looks to be fine to me, not even scratched. These also cannot be found much cheaper then $60 from my brief research. Think I'll be okay running the old driving gear with the new driven gear?
Thanks for any insight,
Matt
   / Model 450 Snowblower repair and tech info needed #2
Hey Matt, I've been doing a little research for my 451 which is basically the same unit and notice gears in brass I would imagine this wouldn't be a bad choice, let me ask was this gearbox producing any noise or chatter before quitting on you? Jim
I ended up ordering the one in the first link from my original post. It looked steel/aluminum in the picture but a very brass gear showed up. I'm glad though, the brass gear confirmed that my old gear was aluminum. The brass one is much heavier. Hopefully that translates to strength. I did my best to clean all the old grease and aluminum shavings out of the gearbox, installed the new gear and bolted it all back together.
I put it all back together on the tractor today and went and blew some old crusty piles with no problems. I guess we'll see how it holds when we get another bigger snow.
JRJP56 Jim, I didn't notice any noise or chattering at all over the sound and vibration of the engine. It seemed to just up and quit. Thanks for the input on the brass gear, I think it will do better than the old aluminum one.
Matt
   / Model 450 Snowblower repair and tech info needed #4
Matt, lots of great info and pics on your repair, Thanks, gives me a great idea as to what I'll be looking at as well. Your gearbox looks identical to mine which has puzzled me after I noticed it's not the same as the parts diagram shows. If you notice the box shown is much larger and has a lubrication plug located at the top, ours has none. Looking at your pics it's pretty tight inside, I had thoughts of drilling the case and installing a zerk fitting, might help to keep these things lubricated. The other boxes take a special oil from what I've been told by the dealer but at $28 for 16 oz maybe we're better off. Glad to hear you're back up and running.
   / Model 450 Snowblower repair and tech info needed #5
I just finished doing the same fix on my walk behind snow blower. I used CV Joint grease, packed it in, tested the covers shut tight. Wiped the edges clean and put on a new gasket. Bolted everything together. Works great. Cheaper than a new transmission which comes with the 2 axles. Total cost was $75.00 for everything. They say the brass is used to save the other gear where the pins did not break. I think mine striped because I was trying to blow 24 inch high snow.
Al
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
Toro Mower (A50324)
Toro Mower (A50324)
JLG 1932R 19FT Scissor Lift (A50322)
JLG 1932R 19FT...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
