Model 316 no spark
   / Model 316 no spark #1
JohnMC
MI
JD 4210
I have a 85 vintage 316 with Onan B43E engine. No spark at the coil/plugs. I have 12v at the coil and test light blinks slightly on negative side of coil while cranking. Points look good & will spark/arc slightly when I insert a feeler gauge w/ign on. Not sure how to check condenser. Check fuses & connectors at ign switch & downstream in the wire harness. Terminals are clean. Anybody have any more ideas before I buy a new coil? Thanks.....
   / Model 316 no spark #2
the condenser is cheap money to replace. Also, the ignition switch is a common fail point on these old machines. I'd replace the condenser first. They usually recommend replacing points at the same time.
   / Model 316 no spark #3
Check the grounds, battery cables, and make they are tight and clean, then check the points and make sure they are gapped correctly. I would also check the battery to make sure that it's still good and has enough amps to fire the plugs.
The points were staying in the open position. Finally fixed it. The points weren't moving because the baseplate that the points attach to wasn't positioned correctly causing a side load on the pin & keeping it in the up position. Once I centered the baseplate the plunger moved freely. After that I diagnosed a bad coil. New coil & all is well. Now I have another issue I'm going to start a new thread on.....
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
