Mobile Plasma cutting
   / Mobile Plasma cutting #1
hudr
Platinum Member
NE Texas
Mahindra 5005DI
Ok, I have Lincoln Ranger 10000. I am about to pull the trigger on a Hypertherm600 plasma cutter. I plan to use it in conjunction w/ the welder on several "on-site" jobs (i.e.:building fence corners way back in the boonies). I notice in the specs it seems to require 6cfm@72psi (if I am reading this correctly). This model does not have an internal compressor. So, I will need to add a rack for a compressor on my 5x8 trailer that is now dedicated to all things "smithy". Anybody else doing something like this already? Any suggestions on a compressor? Looks like I am going to spend another $200-$300 for a compressor to mount on the trailer.
   / Mobile Plasma cutting #2
I don't know if it counts but I once ran the smallish hypertherm plasma cutter and the 5 HP shop air compressor at the same time from my coleman 5500 watt generator. All of this was setting in the back of my pickup running at the same time. It worked, the problem is that the plasma drippings and big sparks kept starting fires on the ground so I had to stop early.
I am pretty sure I have enough electricity to run everything. What I am concerned w/ is how critical is the air pressure/flow rating? Best case scenario: I find the compressor that will give the recommended rating, then go to the next size up.
   / Mobile Plasma cutting #4
The air compressor will become a valuable part of the smithy trailer so I wouldn't worry too much about the meager air needs of the plasma cutter but be more concerned with having enough air for doing things like running air tools and seating tire beads at the remote sites. I would find a compressor that fills the 5 foot width for sure and make it a third part of a threesome.
   / Mobile Plasma cutting #5
You could also just use an inert gas (argon, nitrogen, etc) or air bottles (SCBA type work great) on the trailer rather than buying a compresor. Just a thought.
   / Mobile Plasma cutting #6
</font><font color="blue" class="small">( You could also just use an inert gas (argon, nitrogen, etc) or air bottles (SCBA type work great) on the trailer rather than buying a compresor. Just a thought. )</font>
Inert gas won't work for the plasma cutter. You'd have to use compressed air.
I think I'd get one of those wheelbarrow style compressors. The kind with the two horizontal tanks. They seem to be what most folks mount on maintenance trucks. Definitely something big enough to run a paint sprayer and/or pneumatic nailers.
   / Mobile Plasma cutting #7
I have a hypertherm 600. You can use dry nitrogen. If the pressure drops below it's rated input the cutter will shut down until the pressure comes back up. I'm using a a craftman 2hp compressor and it is right at the bottom of what I would want no problems so far but i've not used it for any long cuts yet.
   / Mobile Plasma cutting #8
</font><font color="blue" class="small">( You can use dry nitrogen. )</font>
I thought they needed the oxygen in the compressed air for the cut?? I guess my wifes right, I don't know everything. /forums/images/graemlins/tongue.gif
   / Mobile Plasma cutting #9
The oxy-acetylene uses oxygen to combust the steel. Maybe the plasma cutter uses a different process.
Found out my answer. I don't think the plasma would be the best choice for what I plan to do immediately with the "smithy" trailer. What I gather from the guys around here is that plasma works best in a "controlled" environment. Don't know how it would fair bouncing around in the pasture going from corner to corner and brace to brace. Also, seems the consumables can catch up pretty quickly cost wise. So for now I have bought a new torch kit to replace the bomb I was using before.
But we will see where we end up w/ the smithy trailer. Hmmmm...need to find me a vise....
Thanks, guys.
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
1275 (A50490)
1275 (A50490)
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
Informational Lot - Financing (A53473)
Informational Lot...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
